Do I need to leave room for expansion - inlay used outside
- Model of CNC Machine: eBay special China 3040
Doing a sign for outside. Probably pine or poplar. The game plan is to cut the letters out and then fit them into pockets. Do I fit them tight, or leave room for expansion/contraction due to weather? If so, how much?
Re: Do I need to leave room for expansion - inlay used outs
No need to.
If the grain runs the same direction, it should expand and contract evenly.
If the grain is the opposite direction, nothing you do will prevent it from eventually cracking.
If you leave a gap for expansion then you have somewhere for dirt water etc to get in which won't help in the long term. Plus if the sign is low down then viewing distance comes in to play a little. Close up it will just make the letters look like a bad fit
Why are you using wood for this sign? Guessing with your choice of pine/poplar you are going to paint it. Would you be better off using composite materials & plastics which then eliminates the need to paint & will last much longer without any maintenance
Customer wants wood. He's going to stain it. I don't have to do it with inlays. But I've found that if you want to stain parts of the thing one Color and the background another, it's easier to make it in pieces and stain first, then glue them in. Haven't been very successful staining just certain parts. One of the pieces will be a relief cut. Almost impossible to stain a separate color.martin54 wrote:If you leave a gap for expansion then you have somewhere for dirt water etc to get in which won't help in the long term. Plus if the sign is low down then viewing distance comes in to play a little. Close up it will just make the letters look like a bad fit
