In the job sheet set up is there some place to have it print the date and time it was created.
Thanks Jeff
Job Sheet set up
Re: Job Sheet set up
One could alter the "function GetNotesBox(job)" in the Setup_Sheet.lua file to write out the date & time as part of the Job Notes section.
As a stop-gap one could enter the date & time manually into the Job Notes field within the .crv file.
If it's printed about the same time it's created then the print setup of the browser you're using generally has options to add date/times etc. Not the same thing as created date/time but probably good enough.
Thanks, Adrian, for the browser "trick"
The filename format I use includes the date and optionally time (e.g. 20180927_1425). I like to keep browser printouts clean. And as the filename is printed on the job sheet I never really need the ability to add a date and time as the OP wants.
Steven
Steven
- Model of CNC Machine: Shapeoko 3D XXL
ADZ Could you be a little more specific on adding the date in the lau section.
Jeff
Jeff
