VCP 9.508 update problem
- Model of CNC Machine: Homebuilt 24" x 48"
Version 9.508 Available! appears in the upper right hand screen, I click on it and it takes me to the download and downloads the file but when it is installing it this message comes on screen.
I have tried this several times with the same result, help please.- IslaWW
Re: VCP 9.508 update problem
Any chance that VCPro is still running, but minimized?
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
VCarve was turned off.
What version are you currently running, before the update?
I had the same problem trying to update Aspire. Use CTRL-ALT-Delete then click on task manager to verify that VCarve isn't still a running process. If you see it in the list then select it and click on "end task". If that doesn't help, and you are running a antivirus program try turning that off and trying the update again.
4D
4D
I am presently running version 9.507
