Hi there, how or where do I copy the patch to update from 9.507 to 9.508?, the computer is not connected to the inter net in the workshop.
Nick
VCP 9.508
Re: VCP 9.508
The updates can be downloaded individually from here but it usually takes a few days to catch up with the automatic release - https://www.vectric.com/support/program-updates.html - once downloaded you can copy the file via a memory card/ thumb drive to the workshop PC.
Each update that is downloaded via the update mechanism stays in the VCarve Program Files folder as well so you can copy the update file from there also.
- Vectric Staff
- Model of CNC Machine: Craft CNC DS1
Re: VCP 9.508
The webpage hasn't been updated yet it seems. In this case, just use this link to download the executable directly http://www.vectric.eu/patches/VCarvePro ... _v9508.exe
Copy that to the installation folder of VCP 9.5 in Program Files and run it. Otherwise, you could download the full installer from the portal which will be 9.508
Mohamed
Mohamed
