Cut2d to Vcarve
Cut2d to Vcarve
With the addition of rotary support to vcarve 9.5 I decided to upgrade from cut2d desktop to vcarve desktop. Are the tool databases compatible between the two products? If so, how do I migrate the data? Are posts compatible?
Re: Cut2d to Vcarve
You can use the export/import feature of the tool data base to move it over. You can actually move the whole thing but there's a lot less to go wrong if you use the export/import of the database itself.
Post Processors are the same these days between the two.
