Flared Corners on inlay
- Model of CNC Machine: OX Custom Build
I am a new user with the VCarve software and have run into a speed bump with obtaining sharp corners with the v-bit. I can produce the correct pockets with the endmill and the VCarve path seems to be right but when it approaches a sharp outside corner, the lines flare out as the bit retracts and the same as it re-enters. I have check all the parameters of the bit to make sure they correspond to the tooling loaded in the software. Any assistance to point me in the right direction would be greatly appreciated.
Re: Flared Corners on inlay
Is your control software Mach3? It may be a constant velocity (CV) setting.when it approaches a sharp outside corner, the lines flare out as the bit retracts and the same as it re-enters
Can you post a photo?
How does it look in the preview?
The other thing it could be is that the angle of the v-bit doesn't match the angle set in VCarve.
I am using Mach4 currently and I have checked all the bit parameters to ensure they match.
I have tried to post a picture and have failed repeatedly. The preview shows square corners but we get what looks like half of a bow tie. As stated earlier, on a letter such as “L”, the line on the vertical part will be correct. As the bit approaches the corner and begins to retract out, it veers outside of that line about 1/16”. It also seems to over run the corner and veers back in to the horizontal line at the top. I will continue to work on uploading a picture.
The photo file needs to be smaller that 2MB. You can resize the photo using various tools to make the file small enough.
- Mike-S
You'll get those kind of corners if the bit angle is more acute than what you specify in the tools. Just because a bit is labeled 60 deg doesn't make it so--could be 57 or 58. I think that's what you're seeing.
- IslaWW
Yup... VBit angle is off. Since it appears less than 90*, all will be acute. Your picture shows an actual that is larger angle than is listed in the parameters
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
You may have a bit that is not the angle that it says it is but I'd like to ask a question that might point in another direction (probably back to Randall's comment about CV setting in Mach 4).
Are all the 6 lines describing the "L" straight?
The two long verticals seem to be. The two shortest lines are indeterminate. The horizontal line for the top of the leg looks like it might be but the very bottom horizontal of the "L" is very wavy. If that is supposed to be dead straight then the v-bit angle plays no part in it being wavy.
You may have a V bit with a significant flat on the bottom. If you define the bit as a V bit in the tool database then there is no field for defining the size of the flat. V carves will end up incorrect.
If the bit has a flat tip enter it as an engraving bit where you can define the bit's angle and flat dimension. Alternatively you can enter it as a form tool where you define the geometry of the bit with a line drawing of the right side of the bit.
Tom
Tom
This is exactly what happened in my situation. When I used my phone to take a real closeup of my 60 degree v bit, I was shocked to see what had happened to the tip. It had become entirely rounded instead of pointed. New bit and problem solved.tomgardiner wrote:You may have a V bit with a significant flat on the bottom. If you define the bit as a V bit in the tool database then there is no field for defining the size of the flat. V carves will end up incorrect.
Tom
