I'm in charge of the CNC at our makerspace. Currently running version 9.
What issues do I need to look out for? Will the 9.5 makerspace version open files made in 9.0 makerspace version?
Are tool databases compatible?
Will our makerspace key work with 9 5?
Should I upgrade the machines to 9.5, or install 9.5 and keep 9.5?
Version 9.5 backwards compatibly (makerspace version)
Re: Version 9.5 backwards compatibly (makerspace version)
Vectric software has always been Backward compatible. You can open 9 with 9.5, but not the other way around.
Gary
Gary
- Model of CNC Machine: eBay special China 3040
Yeah. But I'm not clear if the makerspace key will work.garylmast wrote:Vectric software has always been Backward compatible. You can open 9 with 9.5, but not the other way around.
Gary
I guess there's one way to find out ...
Hi Mike,
The 9.5 version will open 9.0 files, tool databases are compatible, the makerspace keys should be compatible.
However files saved in in 9.5 won't be openable in 9, and so for those members that are perhaps using a version 9 trial then it might be worth keeping version 9 installed as well. The version 9 trial will expire soon though, so those members will have to upgrade to 9.5 anyway.
I hope this helps,
Adam
I hope this helps,
Adam
AdamJ wrote:Hi Mike,
I hope this helps,
Adam
Well, it looks like version 9.5 isn't available yet as a trial version, nor a makerspace version. I'll just have to wait.
