Hello there
Hoping for some advice to machine a profile I have not yet encountered. I have attached 2 files which were provided to me by the customer. All dimensions are in millimetres and essentially I need to machine a sweeping convex profile in an MDF block 400 x 400mm x 57mm thick and a concave sweeping profile and another block of the same size.
My thought process was to draw a series of concentric lines and create a tool path that moves out incrementally at different depths using a ball nose cutter cutting on those lines with minimal step over.
Does that sound right? Perhaps I am not explaining it well but the files should give you the gist.\ and any advice would be greatly appreciated.
I am running latest version of VCarve Pro.
Many thanks in advance. Michael.
Machining Convex and Concave Sweeps
- Model of CNC Machine: Multicam Classic 1000
- TP EXT Curve.crv
- (323.5 KiB) Downloaded 127 times
- TP INT Curve.crv
- (364.5 KiB) Downloaded 94 times
Re: Machining Convex and Concave Sweeps
Hello Michael,
I'm not sure of which tools are available in VCarve, so I will not answer on the method.
You'd better check with your customer what he is expecting. Some dimensions have 2 decimals: which allowance does he expects?
The sharp edges will be difficult to achieve and very brittle.
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
- highpockets
I'd do both of them using the molding toolpath and a couple of profile toolpaths for the ledge cut and cutout.
