I posted this a while back and no one had a answer.
I thought I would get again
I have a Laguna IQ. I have the 4th axis with it also
Does anyone know where I can get a indexing post for the 4th axis for this???
Also the wrapping job doesnt work for what I need .
I looking to cut a pocket and auto rotate for example 30 degrees and cut another pocket .
Thank you.
Doug Patrick
4th axis indexing post
- Model of CNC Machine: LAGUNA IQ
Re: 4th axis indexing post
Here's where Laguna has post processors:
https://lagunatools.com/design-software ... are-posts/
Hope it helps.
Hope it helps.
I went through all of there post and they didnt have what I was looking for. I'm hoping someone had a post I could download
- IslaWW
Doug...
It sounds like you have a wrapped postP for your machine, is this true?
If that is the case, then you have everything that is available. I believe that you need to cut inlay females without rotation on a cue blank but have no way to rotate the blank for multiple cuts. This is normally not too difficult, but is made more difficult when using a pendant controller that has no ability to take keyboard input. You will have to learn to manually edit Gcode files or have a set of premade files that you can load and run, each with a different amount of rotation.
Let me know if I understand what you are trying to do.
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
Hello
Thanks I don understand Here is my problem tho My post doesnt run off g code it runs off mm code
