Vcarve Pro Post Processor removal
- Model of CNC Machine: Custom 5ftx5ft machine with mach3
Is there a way to remove unwanted post processors from Vcarve Pro? I need the ones for Shapeoko 3 XXL (inch and mm) and that's it. There are to many post processors in the software to go thru each time.
Re: Vcarve Pro Post Processor removal
From the File Menu, go to Application Data Folder.
The best way is to copy the post processor that you use from the PostP folder to the MyPostP folder. Then only that post procesor will be available.
Or, you could delete all the other posts from the PostP folder, which will have the same effect.
I couldn't find the folders Postp is there a hidden folder somewhere?
I think I have it thanks
You shouldn't need to hunt down the PP each time you create a toolpath. After you use it for the first time it will become your default PP, ready whenever you create a new toolpath.
Phil
Phil
