Hello, I have been working with a file using the moulding toolpath option, with the larger area clearance tool option. The machining allowance will not work. I thought it was just not showing graphically, but the TAP file shows the exact same roughing depth cuts as the finish path.
Thank you
machining allowance not working
Re: machining allowance not working
Can you post the CRV file, or at the very least some screen shots?working with a file using the moulding toolpath option
This thread might help - http://forum.vectric.com/viewtopic.php?f=2&t=25297
