Tool path error
Tool path error
Postby zaxis » Sat Jul 21, 2018 4:27 pm
Using VCarve pro I was trying to pocket a rectangle 8.25x 7.25. It seems that no matter what I did I would always end up .125 too small each way. I finally just had to expand the pocket within the program by .0625 and use a profile cut to make the pocket the correct size. Has anyone had this happen before? I went back and redrew everything and recalculated the tool paths with the same result. My next job was OK again????
zaxis
Model of CNC Machine: Axiom Basic 4
Re: Tool path error
Postby IslaWW » Sat Jul 21, 2018 4:35 pm
Was the bit diameter the same as listed for the selected bit in the tools parameters?
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Re: Tool path error
Postby martin54 » Sat Jul 21, 2018 7:07 pm
What was the toolpath preview like ? Pretty sure if others were having the same issue then the forum would be full of posts about pockets cutting the wrong size :lol: :lol:
why did you have to expand the pocket size to run a profile cut ? Were you using the same bit you cut the pocket with ? Were you ising a large area clearing tool ?
Re: Tool path error
Postby Adrian » Sun Jul 22, 2018 9:14 am
As Gary says check all the diameters in the toolpath. A common error is to have the description set to something like 'End Mill 0.25' but the actual too diameter is set 0.125". A quick glance leads you to think you have the correct tool but you don't. You need to check the Edit section in the toolpath before checking the tool database.
Re: Tool path error
Postby zaxis » Sun Jul 22, 2018 3:29 pm
Thanks for the advice everyone. I had switched from .375 to .5 but I was very careful to recalculate the tool path. I think for some reason the .375 was stuck in the code. I finally started a new file and did a redo on everything and it was fine again. For whatever reason the bit size would not over write in the code until I started a new file??? :shock: :shock:
zaxis
Re: Tool path error
Postby IslaWW » Sun Jul 22, 2018 4:11 pm
You have to recalculate the toolpath with the new bit diameter and then save a new file, and hopefully overwrite the original.
Gary Campbell
IslaWW
Users browsing this forum: RoyShimp and 43 guests
