moulding toolpath help
I am trying to make a convex arc with the moulding toolpath with a .625 core box cutter. Can't seem to get it the way I want it. Not going deep enough and the end of the arc is a higher z value than the start of the arc.
Re: moulding toolpath help
another picture of actual cut. Do I have to compensate for bit diameter?
- Model of CNC Machine: Probotix Nebula
Try adding a boundary offset of half the bit diameter. Should allow the bit to travel further out and lower down to get the full curve machined.
Scott
Scott
Thanks sseale I will try that asap.
That worked like a charm Scott. Thanks
Glad to hear that worked out good.
Photos please, so we too can revel in your success!That worked like a charm Scott. Thanks
Not only so we can revel in your success but if you can't provide photographic evidence it didn't happenRcnewcomb wrote:Photos please, so we too can revel in your success!That worked like a charm Scott. Thanks
On a serious note a picture would be a good way to show others just how well Scotts advice helped solve the problem, will help others with the same problem
