Flower of Life
Flower of Life
I am trying to make a flower of life carving. Something along the lines of this https://all-free-download.com/free-vect ... 16823.html I want to Vcarve all the white area and leave the dark tall. I am probably approaching it all wrong, but short of drawing each and every white area, I am running into all kinds of overlapping or duplicate lines issues. Anyone have any suggestions on the best way to approach this design?
- Mike-S
Re: Flower of Life
You can use the "chicken" (bluebird) icon to vectorize the line art, but you'll find that it puts a vector on both sides of each line.
Also you need to put a vector around ALL of your vectors to reverse the carve and make the black lines proud.
- highpockets
- Mike-S
Re: Flower of Life
HP, How'd do du dat?
- highpockets
Re: Flower of Life
Mike,Mike-S wrote:You can use the "chicken" (bluebird) icon to vectorize the line art, but you'll find that it puts a vector on both sides of each line.
He doesn't have the chicken.
- Mike-S
Re: Flower of Life
I always get in trouble trying to advise on V-carve.
- highpockets
Re: Flower of Life
I found a high resolution image of the Flower of Life. Imported the bitmap. Used black and white trace and tweaked the trace.Mike-S wrote:HP, How'd do du dat?
Now comes the fun part, I created three separate vcarve toolpaths making sure not to select two vectors next to one another. I used a 1/2" 90° vbit.
- highpockets
Re: Flower of Life
Me too....Mike-S wrote:I always get in trouble trying to advise on V-carve.
Re: Flower of Life
Ohhh - is that what that thing is? I didn't know that.
Re: Flower of Life
The images I found weren't high enough quality apparently. The vector image I linked to wasn't accurate enough. So I was trying to draw it myself. I was mainly trying to use circular arrays but of course am ending up with all kinds of overlaps. Originally I was making it so the top came to a point at the lines. It did dawn on me that making the tops be a narrow flat would work better both carving and getting rid of some overlapping issues. I am going to keep trying to draw it before I give up and go back to the Chicken
- adze_cnc
Re: Flower of Life
Given the colouring of the icon surely it's not a chicken but rather a pigeon...
Re: Flower of Life
Problem with the vectors in your link is they weren't drawn for v-carving so there are open vectors where the software needs closed etc and gaps when you zoom right in. A common issue when taking vectors drawn for the human eye to look at rather than a program to try to machine from them. The advantage of using the auto trace on a nice clean black and white line drawing is that it generate vectors that are suitable for v-carving straight away.
It's not a chicken, it's a robin. Look at the wording on the picture.
Re: Flower of Life
Shortly after I posted this morning, my wife walked in and asked what I was doing. She immediately told me what I was doing wrong, since she works with these kinds of patterns all the time in quilting. I now have it arrayed with no overlapping lines, just need to trim to the outer circle.
- Mike-S
Re: Flower of Life
Clearly, it's a chicken named "Robin."It's not a chicken, it's a robin. Look at the wording on the picture.
Re: Flower of Life
Here's a clean .dxf file I threw together.
- Flower_Of_Life.dxf
- (79.75 KiB) Downloaded 168 times
