Adding G91.1 automatically in v-carve?
- jaru-eri
- Model of CNC Machine: Taig and router, Gecko G540, Mach3
Will it be possible to change the settings in V-carve to add G91.1 as the first line in order to always have a correct circle function when using Mach3?
Re: Adding G91.1 automatically in v-carve?
You can edit the post processor you use or create a new one to have any commands you would like in it. There is an editing guide on the VCarve Help menu.
Mach3 posts already have a G91.1 in them.
