My G code wont load
My G code wont load
Postby Daner » Wed Jul 04, 2018 5:54 pm
I dont know what happened, but I cant load and G codes into Mach 3
It will show the file below the gcode box but nothing seen in the gcode box
Any help is apreciated
Daner
Model of CNC Machine: Industrial 8x4
Re: My G code wont load
Postby 4DThinker » Wed Jul 04, 2018 8:03 pm
One possibility is that your file is corrupt. If you created the g-code on another machine and saved it to a thumb drive then pulling the thumb drive out before the machine is done with it will screw up the file allocation table and leave the file corrupt.
If the file is a huge 3D file it may be too large for the memory of the machine you have mach3 installed on.
Without more info from you these are the best suggestions I can come up with.
4DThinker
Postby ger21 » Wed Jul 04, 2018 9:04 pm
In the pic, it looks like you are trying to open a shorcut, not the actual g-code file.
ger21
Postby Daner » Wed Jul 04, 2018 11:03 pm
I had the wrong setting of type of file selected.
It just changed on its own....All is good now
Happy 4th to the south
Cheers
Daner
Users browsing this forum: WarrenGlass and 35 guests
