Help please
Help please
Postby cliftont » Tue Jul 03, 2018 3:09 pm
I am trying to profile cut a simple Letter of the alphabet. Upon completion of the first cut, it gradually ramps up on its way to the second plunge, leaving an unwanted trench. I'm thinking I clicked a button I shouldn't have. Any Ideas
cliftont
Model of CNC Machine: Shark HD 4
Re: Help please
Postby Adrian » Tue Jul 03, 2018 3:22 pm
Assuming you've cut successfully before I would check the material thickness is correct. If you are zeroing the Z to the table surface and you've got the material thickness wrong you would get that behaviour.
Re: Help please
Postby cliftont » Tue Jul 03, 2018 3:52 pm
Thanks Adrian, however I have tried that to no avail. I have the feed rate at 100 and the plunge rate at 30. which has been great up to now. Any other ideas?
cliftont
Re: Help please
Postby mtylerfl » Tue Jul 03, 2018 3:56 pm
Perhaps you can post your file so we can see if anything is amiss there.
Re: Help please
Postby cliftont » Tue Jul 03, 2018 4:37 pm
Here you go
bigb.crv
(245 KiB) Downloaded 37 times
cliftont
Re: Help please
Postby adze_cnc » Tue Jul 03, 2018 5:12 pm
Preview looks good so:
1. machine control software problem?
2. what post-processor are you using?
My machine's manufacturer provided a variant of the Vectric post-processor for their machine that I had to change. When changing a tool from the ATC it would ramp down to the starting point to save time. Problem is if you had things in the way it would crash into them.
I wonder if this is the same sort of problem where either 1 or 2 is ramping up to the next start point inappropriately.
adze_cnc
Re: Help please
Postby cliftont » Tue Jul 03, 2018 5:19 pm
I am using the Shark HD - So you saw nothing wrong with my programming? I am online with vectric support now.
cliftont
Re: Help please
Postby Adrian » Tue Jul 03, 2018 7:07 pm
Is it supposed to be a tiled job?
The job doesn't fit on the material in either direction so you're losing part of the B to the right where it's running off the board. Look at the toolpath preview in the 3D view and you can see where it's moving up out of the material. Doesn't sound like your problem but it's probably not what you would want to be doing.
Re: Help please
Postby cliftont » Tue Jul 03, 2018 7:12 pm
It appears that my machine is stuck on the laser post processor. It gives me no other option. try to figure out how to change it. Thanks for the heads up
cliftont
Users browsing this forum: WarrenGlass and 33 guests
