Does anyone know if I can inport a Font I like into VCarve. If so how? I found some fonts online to download but not sure if I can load them into the system
Importing Fonts
- Model of CNC Machine: Shark HD4
Re: Importing Fonts
How can I add more fonts?
Additional True Type and Open Type fonts (.TTF) can be obtained from many sources and available to use once the font has been properly installed the Windows Font Directory and the program restarted.
This is not hard to do and typically if you right click on the font file, it will give you the option to install the font. If that option is not available, the exact process can be found in the Help Document for your version of Windows.
The included Single Line Fonts are installed during the program's installation and cannot be changed or added to.
http://support.vectric.com/aspire-quest ... -add-fonts
Re: Importing Fonts
Thank you
