3d first timer issues
Postby connalj » Mon Jun 25, 2018 6:26 pm
Hi folks,
I am trying to make a 3d Rose be above the material (raised).
So the first thing, I need to do is rough it, but how do I remove the material around the rose completely. This will be a box lid.
connalj
Model of CNC Machine: Shopbot Desktop max
Re: 3d first timer issues
Postby martin54 » Mon Jun 25, 2018 8:25 pm
There are several ways it could be done, one method would be to machine the whole work piece using the material as a boundary, easy to do but the downside is the finish quality on the flat areas of the lid & the time taken to machine it all using 3D toolpaths. Another method would be to use a vector boundary & just machine the rose using 3D toolpaths & then pocket the rest of the lid down to the required depth. Quicker method but requires a bit more accuracy setting up to ensure you don't get a step where the 2 meet :lol: :lol:
There are quite a few tutorials on 3D machining & also some tutorials on efficient 3D machining in the 2015 user group section :lol: :lol:
Postby Leo » Mon Jun 25, 2018 8:41 pm
I do the pocket like Martin said around the outer periphery of the model boundary.
Just a little tweak though. What I do is create the material boundary then painstakingly node edit to get the boundary as smooth as possible and as few nodes as possible. Then I offset "IN" a few thousandths - maybe .01 or so.
Also - I set the pocket deeper than the model, so that there is a little bit of straight sides on the outer periphery of the model.
By doing this I get a nice flat surface of the outer pocket area right up to the model with no step. Nice clean look.
www.leosworkshop.com
Leo
Postby connalj » Wed Jun 27, 2018 5:39 pm
Everyone.
Thank you for your input. I am looking forward to trying out each process to build my experiences:-)
connalj
Users browsing this forum: Google [Bot] and 32 guests
