15 posts • Page 1 of 1<Previous topic | Next topic>
Arnell wrote:I have seen a similar problem with a laser engraver. A notebook computer was used on the machine and the problem turned out to be the computer was going into power saving mode.
Hope this helps.
martin54 wrote:Arnell wrote:I have seen a similar problem with a laser engraver. A notebook computer was used on the machine and the problem turned out to be the computer was going into power saving mode.
Hope this helps.
Just to add to this because sometimes turning off or disabling power saving features is not enough![]()
From your profile it looks like you have a home built machine, so how much you need to optimise your computer will depend on a number of different factors like what operating system you are using, what control software, the type of motion control & how that is connected to your computer are all factors.
As an example Mach3 running via parallel port control does not like anything else going on in the background so the best set up would be a computer stripped of just about everything other than mach3 with no internet connection, anti virus software & anything to do with operating system updates turned off![]()
Users browsing this forum: No registered users and 30 guests
