I need to set up rapid z gap above material
it look like it has a default setting of 0.2
i need to set this to .5 . but when i do and i restart vcarve it goes back to 0.2
i need it to remain at .5 until i need to change to another number
Material setup
Re: Material setup
It's a setting that stays at the last used value or what is set in the file. So if you load a file it will be whatever that file was saved with. If you start a new job then it will be whatever the last setting was set at.
Those settings do work with each other so the Rapid Z and Gap Above Material will all change to sensible values if what you enter doesn't make sense.
Re: Material setup
Thanks adrian got it
