tight vector?
tight vector?
Postby weirdbeard » Fri Jun 08, 2018 6:34 am
Hi All,
Im trying to create a vector around the selected vectors - However the create Vector Boundary tool is not giving me quite what I want
Is it possible to somehow create a "tight" vector around the selected vector? or am i just going to have to manually edit what I have here with in node editing mode?
Perhaps Im being thick - I hope so haha
Lee
weirdbeard
Model of CNC Machine: Jcut
Re: tight vector?
Postby FixitMike » Fri Jun 08, 2018 7:05 am
Copy all of the vectors to a new layer. Turn off the previous layer.
Use the Weld tool on the copied vectors to get the tight outline.
FixitMike
Re: tight vector?
Postby weirdbeard » Fri Jun 08, 2018 7:17 am
Thank you Mike, certainly got me a lot closer however still going to need some editing - Im unsure if this is the expected result...
Lee
weirdbeard
Re: tight vector?
Postby FixitMike » Fri Jun 08, 2018 7:29 am
That's not the result I would expect. Can you post the .crv file?
Also, try using the weld tool a second time. And/or using node edit tool to see if there is something unusual about the original drawing. Although I wouldn't expect to find much.
FixitMike
Re: tight vector?
Postby weirdbeard » Fri Jun 08, 2018 7:46 am
Thanks again for your help Mike :)
TH1.crv3d
(1.73 MiB) Downloaded 43 times
Regards
Lee
weirdbeard
Re: tight vector?
Postby FixitMike » Fri Jun 08, 2018 8:03 am
If there are vectors in the original drawing that are not closed, It looks like the weld tool will do funny things with them. I've submitted this bug to Vectric Support.
FixitMike
Re: tight vector?
Postby Adrian » Fri Jun 08, 2018 8:13 am
I don't use the weld tool for jobs like that. I select the outside vectors, copy/paste them and then use the trim tool to remove overlaps. The Weld tool has always had "odd" behaviour depending on the order vectors are chosen in, whether they are grouped or not, how far they overlap etc so I prefer the manual approach to know what is going on.
TH1 - v2.crv
(1.73 MiB) Downloaded 32 times
Re: tight vector?
Postby weirdbeard » Fri Jun 08, 2018 8:23 am
Thanks Guys - Seems like it would be a great additional option to be included with the create boundary tool
weirdbeard
Re: tight vector?
Postby sharkcutup » Fri Jun 08, 2018 4:42 pm
I used the boundary tool then used the node editing (15 minutes)
Sharkcutup
Facebook: Hogan's CNC Crafts
Website: hoganscnccrafts.com
V-Carve Pro 9.511
sharkcutup
Users browsing this forum: jerry carney and 45 guests
