Grbl support
Grbl support
Postby Tony Pagett » Thu Jun 07, 2018 8:35 pm
In Cut2D I use Grbl (mm) (*.gcode) as my Post Processor.
In the trial version of Vcarve this option is not there.
Does it appear in the full version?
If not, are there any suggestions which Post Processor I should use?
Tony Pagett
Model of CNC Machine: Openbuilds C-Beam
Re: Grbl support
Postby vgraves » Fri Jun 08, 2018 5:09 pm
I don't remember all the restrictions on the trial versions, I know they limit what files you can actually machine, but I wouldn't think they'd restrict what machine you cut them on. Can you copy the post processor file from your Cut2D PP folder to the Vcarve Trail PP folder?
vgraves
Model of CNC Machine: CNC Router Parts PRO4848 w/LinuxCNC
Re: Grbl support
Postby martin54 » Fri Jun 08, 2018 10:08 pm
As far as I am aware the trial versions are the most upto date software & include a full list of supported machines. If the Post Processor you require is not in the list then your best bet would be to contact Vectric Support or if your machine has a forum you might be better asking on there as the chances are someone will have one :lol: :lol:
Users browsing this forum: 4DThinker, sylvan356 and 30 guests
