Help Please
Re: Help Please
Postby neshra » Mon Jun 04, 2018 7:38 pm
Actually I really don't need shimming. I use Tapping Inserts and when I bolt down that metal brace they don't move at all. I just think it is certain areas of the wood.
(8.98 KiB) Not downloaded yet
neshra
Model of CNC Machine: ShopSabre 23
Re: Help Please
Postby Adrian » Mon Jun 04, 2018 10:04 pm
Don't underestimate the forces involved when cutting. I've secured material that I couldn't budge with all my strength yet it still moved when cutting.
Re: Help Please
Postby martin54 » Mon Jun 04, 2018 11:55 pm
Not sure how many of these you are doing at a time, if it is only 5 as in the photos then there might not be anything gained by having to do a bit change but if I had a job like this then I would look at pocketing with a larger bit to reduce the time it takes to machine the pockets & then run a profile toolpath with the smaller bit to reduce the corner radius
Could save you quite a bit of time if you could fit a much larger quantity in a jig at the same time :lol: :lol:
Re: Help Please
Postby cbr_speedster » Tue Jun 05, 2018 1:04 am
Maybe the pockets need to be cut larger to use a wedge on two sides to hold the parts from moving.. Also, have you tried roughing the pockets leaving .020 - .030 for a finish pass?
cbr_speedster
Re: Help Please
Postby Ken Tipton » Tue Jun 05, 2018 6:44 pm
neshra
I live only a couple of miles from you. Let me know if you would like to get together sometime and maybe we could figure it out together. I have a CNC and lots of bits to experiment with.
Ken
Ken Tipton
Previous
Return to VCarve - General
Users browsing this forum: No registered users and 32 guests
