I want to cut out some boat oar's to use for signs at out lake house.
And ideas on where I could get a file that would work in Vcarve Pro.
Would like it to shape down the paddle part. Maybe it would need to be a 2sided job
Cut out the handle and then I could round it on my router table
Jeff
Boat Oar
- SteveNelson46
Re: Boat Oar
Design & Make has one in one of their collections. Search for "Boat Oar"
http://designandmakeit.com/
- Model of CNC Machine: PRS Buddy48alpha ,4x6' 130w laser, Wazer
Re: Boat Oar
Here is one that would work well for a sign- $4 https://www.turbosquid.com/3d-models/pa ... 3ds/956283
- Mike-S
Re: Boat Oar
Try this.
Done with two-rail sweep.
- oar-stl.zip
- (1.48 MiB) Downloaded 140 times
- Model of CNC Machine: Shapeoko 3D XXL
Re: Boat Oar
I downloaded the file ,Now how do I get it into Vcarve pro
Jeff
Jeff
- Mike-S
Re: Boat Oar
Unzip, then import .stl file.
Re: Boat Oar
I found the type of oar I was looking for and can import it in to v carve pro.
But Now I need to learn how to size it and set up tool paths to cut it.
So where would I find a tutorial on how to do this.
Jeff
Jeff
- paddle 01 (1).zip
- (545.26 KiB) Downloaded 141 times
- Mike-S
Re: Boat Oar
I'm assuming VCP has the same screen options as in Aspire below.Now I need to learn how to size it
The paddle imports as a VERY large model. Try adjusting the Z first to match your material.
You can also use the "handles" in the greyscale to adjust size and rotation.
This is a pretty basic carve, so if you're unsure, you probably need to start at the beginning of the tutorials and work through one by one.where would I find a tutorial on how to do this.
