problem with a pocket
hello everybody, I am new to cnc and vectric software. I am designing a sign to carve and inside the pocket the software keeps ignoring the T in faith I have tried everything I can think of . I will upload a copy of the file. Thank you for your help. jimalee
- bigger.crv
- (1.11 MiB) Downloaded 90 times
Re: problem with a pocket
It's because the script font has overlapping characters. You need to remove the overlap by converting to curves and then weld or use the trim tool.
thank you Adrian, did like you said and it work perfect. I really appreciate the help.
