Stack Text
- Model of CNC Machine: Piranha LX
- highpockets
Re: Stack Text
Looks like you forgot to run the "Clear" toolpath on the last layer.
Re: Stack Text
Thanks.
Only been at this 2 months, I'm learning.
How is that done?
How is that done?
- highpockets
Re: Stack Text
If you don't mind posting your VCP file it would be easier to help.
Re: Stack Text
I'm using vCarve Desktop 9 with a Piranha XL, 'TAP" files are generated for it.
- highpockets
Re: Stack Text
You still have a VCP file saved with your project including toolpaths. That what would help to see.
Re: Stack Text
vCarve Desktop save 'CRV' project file and forum won't upload it, as it exceeds 3MB
- highpockets
Re: Stack Text
Try zipping the file or put it in Dropbox or Google Drive and post the link.
Re: Stack Text
Learning something everyday.
- DEW Stack Text 04_26.zip
- (881.2 KiB) Downloaded 71 times
- highpockets
Re: Stack Text
I thought that too but when I looked closer at the preview and the picture they are not the same. In the preview the top level of the letters and the uncleared portion are at the same z level. In the picture they're not.
On the O and D the darker grain pattern would continue across if the bottom clear toolpath hadn't been run but it's been machined away.
- highpockets
Re: Stack Text
I see what you mean Adrian.
The only other thought is the Z height for the clean up tool on the lower level wasn't set correctly and cut too deep.
Re: Stack Text
Cutting Depths
1St Level
Start Depth - 0
Cut Depth - 0.05
2nd level
Start Depth - 0.05
Cut Depth - 0.1
1St Level
Start Depth - 0
Cut Depth - 0.05
2nd level
Start Depth - 0.05
Cut Depth - 0.1
- highpockets
Re: Stack Text
It's not your design that's fine, but if you don't set the Z zero for the Clear tool and Cleanup tool the the same spot there will be a difference in cut depths.
How are you setting the Z zero for both tools? And where?
