Which Toolpath Operation to choose?
- Model of CNC Machine: Ooznest Workbee
Hi All
New user to CadCam/CNC operations and very 'green' on Vectric!
We have started to cut a varying amount of profiles from flat product as part of our product range using our newly acquired Ooznest WorkBee.
We have been asked to bid for the cutting of 4 variations of the same design. This involves an outer profile and an inner, this is where we are having the issue. The inner profile has a central circle with four slots running from the centre stopping short of each corner. The material we are cutting from is 50mm (2") thick, the slot width is 54mm wide but at each end the slot finishes with a semi-circular profile sloping from the bottom to the top face. As a non-sloping profile this would be easy to draw and process but the slope is throwing me into great confusion.
I tried the Fluting operation but that doesn't seem to give the desired effect, it also finishes with an ellipse rather than a semi-circle.
I have attached a sketch of what is required. What do you guys think? We are running VCarve V9 by the way.
- sharkcutup
Re: Which Toolpath Operation to choose?
What is the depth of the slots into the 2" material??? Or are they Through Slots???
Sharkcutup
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
Sharkcutup,
The answer to your question can be found in section A-A (although that 29mm is probably rounded off).
- Model of CNC Machine: WinCNC Hybrid
I didn't see the width or depth before doing the little video but here is how I'd try it. You can still use the math to get what you need I think.
Mike Queen
Microsystems World CNC (WinCNC)
https://www.youtube.com/user/cncMike304
Yes, they are through slots.
Initially we had considered just using our pillar drill with the table angled to 30 degrees but again, this would create an ellipse. The other downside would be consistency and repeatable quality, as there is likely to be a number of these.
Wow, thanks Mike. So a 60* bit to run without cutting the slot sides but finishing off at the end? I'm going to have a play with that, thanks again.M Queen wrote:I didn't see the width or depth before doing the little video but here is how I'd try it. You can still use the math to get what you need I think.
I'll post up any updates.
Thanks all of you!
Phil
I used the finishing operation to cut this with a 1/2" ball mill.
- FixitMike
The attached picture shows how it can be done with the fluting tool using a series of parallel vectors.
Keep in mind that the fluting toolpath defines the path of the center of your tool.
- FixitMike
Note that for my fluting method, if you cut the pocket first, you can increase the plunge rate and the pass depth for the end mill to considerably reduce the machining time, as there is not much material removed on each pass.
That is uncanny, I think I'll ship the board to you and you can finish them of for me!cbr_speedster wrote:I used the finishing operation to cut this with a 1/2" ball mill.
Thanks Mike,FixitMike wrote:The attached picture shows how it can be done with the fluting tool using a series of parallel vectors.
That is certainly expanding the capabilities of these toolpaths. I think I'll have a go with this.
Hey cbr, I'm in the UK and whilst I've been sleeping you guys have been very generously offering your advice. Lots to think about (now that I'm awake ).cbr_speedster wrote:Well, what did you end up doing?
I'll keep you posted and thanks again all.
Phil
Thank you Mike, you just taught an old dog a new trick.The attached picture shows how it can be done with the fluting tool using a series of parallel vectors.
Mike Queen
