I have been able to cut the shape I want which is a half circle cut on the X-Z or Y-Z axis. I have been using a moulding tolpath where the drive rail is a 0.0001" rail then the profile is a half circle. I have attached a screengrab of this cut at the edge of a block to show the result.....so all is well but I find the way the stepover is handled makes for about a 15 second cut. I am setting up for production and feel that it is possible to get these cuts down to a few seconds.
I have tried using a fluting path with a curved ramp in on each end of a profile but, I can't get it to do a proper half circle shape. I have attached a pic of what this profile looks like.
The final profile is a 1.5" long, 0.75" deep but 1/4" wide recess cut with a 1/4" bullnose bit.
Thanks in advance for any advice!
Half Circle on Y-Z
- Model of CNC Machine: Frankenstein :-)
- IslaWW
Re: Half Circle on Y-Z
Hand code with Gcode arcs in the G18 or G19 plane. Works like a charm, but this will not be generated by Vectric products. Very few will do this.
The "advance per revolution is much higher than you would desire, but here is a hand coded version with full circles:
GCnC Control
GCnC Control
Thanks for the quick reply! I'll have to try the G18 G19 I have to do 8 passes of the shape on one job so it will take a bit of g-code but i'm sure the learning experience will be worth it.
cheers
-Dan
cheers
-Dan
The FlutePlus gadget can do it from the Vectric programs, and let you visualize the results too.
Paul Rowntree
Hey Paul, Thanks for the additonal suggestion, I will have to upgrade before I can install that addon as I only have VCarve Desktop. On another note I was able to do some hand coding to get pretty much where I needed to be. To make live easier, I created a gcode file where I just did straigt lines where I wanted the half circle cuts on the z-y to be. Then I only had to make a couple changes to the overall file to switch to g19 and program the half circle.
The one issue I ran into is that if I cut an exact half circle, it is off shape because the point of the ballnose cutter is following the line so if I am doing a 1.5"x0.75" deep half circle with a 1/4" ballnose, the resulting cut will be 1.75" wide by 0.75" deep. So I had to actually do 2 separate arcs and make the distance of the cut 1.25" and adjust the radius of the arc. I know that with the moulding toolpath I was using mach3 did calculate proper compensation for the cutter. For reference sake, I have included 2 previews
Of course, if you are viewing this post and thinking ..... all this jackass has to do is __________ to get proper compensation for the bit I am all ears \
-Dan
-Dan
You can program to the center of the tool. Make the toolpath 1-1/4" x 5/8", starting at the surface, and set Z zero 1/8" below the surface.The one issue I ran into is that if I cut an exact half circle, it is off shape because the point of the ballnose cutter is following the line so if I am doing a 1.5"x0.75" deep half circle with a 1/4" ballnose, the resulting cut will be 1.75" wide by 0.75" deep
Fwiw, Mach3 is not calculating any offset or compensation with your moulding toolpath.
