Problems with extending lines
Rubiconlwb
Model of CNC Machine: Piranha XL
Post by Rubiconlwb »
This does not happen often but has happened to me a couple times. Occasionally when I extend lines to the intersection of another line, the extension is sometimes too long or occasionally not long enough, stopping short of the line. I can't see that I am doing anything different on these occasions. Does anybody know what could be happening?
Re: Problems with extending lines
Post by Rcnewcomb »
Do you have Grid snapping on?
Rubiconlwb
I'm not sure if I had grid snapping on or not but it happened on several separate lines. I even had some lines that went past the intersecting line and some that were short of the line.
4DThinker
Post by 4DThinker »
I've had trouble when what I wanted to extend a line to was part a group and there were other vectors nearby. Check to make sure the destination vectors isn't part of a group.
