Bitmap toolpath frustration.....
Re: Bitmap toolpath frustration.....
Post by mtylerfl »
I must have missed that Chet wanted cutouts (except perhaps the main outer circle). I thought he was just pocketing around all the internal areas (not wanting to go all the way through the material).
ChetR
Model of CNC Machine: Pranha FX
Post by ChetR »
There is some confusion here....
I do NOT want to cut out the parts for use individually.
The sundial base is actually 3/8" thick.
I am creating a styrofoam pattern that can then be vaporized by molten aluminum in a foundry flask.
(similar to lost wax casting)
So the design is cut into the top half of the actual pattern.
The individual elements remain part of the base.
In more complicated cuts I actually have design features that are cut to a different depth than the surface.
Effectively a bottom, midway, and top, all on top of the 3/16" 10" diameter base.
But that's a whole new learning curve.....
You can see how I've been making these by going to: www.ancrsundials.com
Got to the Testimonials tabs and you can see more examples.
Please please please do not consider this advertising!
This is simply a way to illustrate what I am actually trying to with my new Vectric software,
as opposed to my earlier method of sundial designs....
LittleGreyMan
Post by LittleGreyMan »
It's not a cutout, as the material thickness is 0.5" and the cutting depth is 0.1875
Chet, when you encounter an issue, better post your file if you don't mind. Somebody will very quickly answer your questions.
Best regards
Didier
W7 - Aspire 8.517
Post by mtylerfl »
Chet, your sundials are fantastic! Man, what a great combo for CNC and foundry work!
I will need to spend more time on your website. Looks very interesting!
Thanks for sharing that with us.
sharkcutup
Post by sharkcutup »
Sorry ChetR
I got rather Busy, Busy, Busy!!!
The sundial I prepared is 12" x 12"
For the most part it was cut using a .25 End Mill but there were some areas like between the numbers in which I had to clean up using a .0625" End Mill
Here is the attached .crv file (Note it was done in VCarve Pro 8.5)
4137 Ann Arbor 4.crv
(1.36 MiB) Downloaded 61 times
Glad to you have got it though!!!
Sharkcutup
V-Carve Pro 12.005
