v-inlay technique problems
bk3132
Model of CNC Machine: shopbot PRSStandard 48-96
Post by bk3132 »
Hi everyone,
While I have had decent success with V Carve's built-in inlay toolpaths, I also need to use the v-inlay technique for finer details that require sharp corners. And I'm having a problem. For the most part the male pieces are coming out well and "fit" ok in the female pockets. But as you can see in this close up, something is off. I am not getting sharp corners, and it's almost like the v bit is slightly dogboning the corners. The straight portions machined quite well and are a good fit for the male parts.
I am using a 60 degree v bit for both cuts. Female pocket machined to .15" flat depth using the v-carve toolpath with a 2% stepover to clear out the pocket. Male parts are mirrored, offset outwards .18" and then v-carved at .1 start depth and .1 flat depth to create inverse parts.
Any ideas?
Thanks!
Brian
Paul Z
Model of CNC Machine: shopbot PRT Alpha 96x48
Re: v-inlay technique problems
Post by Paul Z »
Your bit may be "a bit off" in terms of angle. Check this http://forum.vectric.com/viewtopic.php?f=3&t=2164.
Paul Z
bk3132
Post by bk3132 »
Paul Z wrote:Your bit may be "a bit off" in terms of angle. Check this http://forum.vectric.com/viewtopic.php?f=3&t=2164.
Paul Z
Thanks Paul Z. That is intriguing and, well, I never would have thought about it!
I read through that thread, and near the end someone's post got me thinking. In addition to bit angle discrepancies, could my problem also be stock that isn't flat enough or z zero that is slightly off? I suspect those "dogbones" in the corners happen either when the bit plunges or retracts. If zero is off or stock isn't flat, the bit could end up plunging too early, right, which would cause that extra little bite out of the corner?
If so, I guess I have to investigate both issues.
tomgardiner
Model of CNC Machine: FMT Patriot 4 x8
Post by tomgardiner »
Have a look at the bit's tip is there a flat? I think there is a greater likelihood of having a flat tip or dull tip than a cnc ground cutter being out of specified angle. The effect of a flat tip that isn't specified in tool geometry is similar to one with a wrong angle. The cure is to draw the tool with the flat as a form tool or engraving bit.
I don't see much evidence of not flat workpiece.
FixitMike
Post by FixitMike »
Why are the male parts offset outwards? I can see that that is not the cause of the problem you are asking about, but I am curious why there is an offset outwards. I've not done any offsetting and the results have been fine.
bk3132 wrote: Male parts are mirrored, offset outwards .18" and then v-carved at .1 start depth and .1 flat depth to create inverse parts.
Thanks!
Brian
bk3132
Post by bk3132 »
FixitMike wrote:Why are the male parts offset outwards? I can see that that is not the cause of the problem you are asking about, but I am curious why there is an offset outwards. I've not done any offsetting and the results have been fine.
Mike, I offset the vectors so that I can make the software carve the male part inverted as pictured. Is there another way? I'd love to know! Thanks.
bk3132
Post by bk3132 »
tomgardiner wrote:Have a look at the bit's tip is there a flat? I think there is a greater likelihood of having a flat tip or dull tip than a cnc ground cutter being out of specified angle. The effect of a flat tip that isn't specified in tool geometry is similar to one with a wrong angle. The cure is to draw the tool with the flat as a form tool or engraving bit.
That's interesting. I will have to take a look tomorrow. It's the Onsrud 37-82 60 degree V bit, which, I believe, isn't supposed to have a flat tip. But then again I might have given it one! To tell you the truth, I have always worried about that particular bit and the automatic z zero plate/zeroing process. I have to believe that dulls the tip over time, right??
FixitMike
Post by FixitMike »
I draw a rectangle (or other closed vector) around all of the male parts and select it as well as the parts for the VCarve toolpath. I use a flat area clearance tool to clean up the wide areas. That way I have only a single piece to glue in place. (Unless, of course, it turns out to be more convenient to cut the male part into separate pieces for the glue up.)
potzmannwoodshop
Model of CNC Machine: 2 SCM Routech Record 120s(1999, 2001)
Post by potzmannwoodshop »
This is your problem.
Watch the toutorial again, you are missing a huge step. You need to copy the artwork, mirror it, draw a bounding box and then vcarve the whole thing inside the bounding box to get the mirror image male plug
bk3132
Post by bk3132 »
It’s not the problem. The male inlay parts are fine. What I’m doing is essentially what you have written. In this case, though, it’s easier to glue up the inlay parts individually. So my bounding boxes are simple offset vectors, and all told I machine far less this way and can arrange the individual male parts for optimal stock usage rather than as they would actually inlay on the piece.
Bill_L
Model of CNC Machine: ShopBot PRS Alpha
Post by Bill_L »
Brian,
A long time ago my Shopbot was VCarving with the same type of results. Turns out that the Z axis pinion was not seated on the stepper shaft far enough and was binding. When you get to corners in the geometry the Z pulls up while still moving in the X and Y. If it doesn't retract high enough you get what appears to be an overcut in those areas.
Check the integrity of your Z axis and make sure that everything is ship shape.
Bill
bk3132
Post by bk3132 »
Well, I think I have my answer. After tugging on the machine every which way I can't say I feel much of any slop. So I cut a bunch of squares defining the 60 degree bit's geometry differently for each of them, and they ALL had the same extra scooping out at the corners. So I looked at the bit more carefully and see now that it's probably rounding at the tip. Then I ran the original v inlay pocket toolpath using a newer 90 degree v bit, and presto, sharp corners.
Is it possible that my z zero plate is contributing to the dulling/rouding of v bits?? I cringe every time I watch that point hit the metal plate...
Thanks everyone.
Brian
Bill_L
Post by Bill_L »
Brian
I don't think that's the case. The bit I used for this has been in service for over 2 years.
Bill
