I have bee searching for a 3D model of a Dutch windmill.
Not having any luck.
Any help is appreciated.
Thank you.
looking for a dutch windmill
- Model of CNC Machine: Xcarve
Re: looking for a dutch windmill
For some reason I cant open the files.
This is the message I get.
What am I doing wrong?
- mezalick
You need to import the file not open it..
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
Hmmm.
I click on the import button, then my only option is to click "open"
Create a new file, go to the file menu, select Import/Import Component 3D Model. Select the SKP file you want to load and click Open (or double click on the file).
If that comes up with the same error then you will need to download the file again as it may not have downloaded correctly.
