A start depth same as the material thickness?? I see high potential for bad things ahead. Something is not right.
I am having a very hard time understanding why you are having such difficulty with setting Z-Zero to the spoilboard. It's normally a very (very) simple matter of simply touching off the bit wherever you want the z-zero location to be (in this case the spoilboard aka bottom of material), then proceed to run your project.
Seeing your actual file would help us help you.
Material Setup Using Machine Bed as z-zero
- mtylerfl
Re: Material Setup Using Machine Bed as z-zero
- Model of CNC Machine: OOZnest 1500x1500
Michael:
As far as I can tell, my controller software is not accepting the location of the z=0 designated by Vectric. It seems to only understand where the bit is at the moment.
I've tried to designate z=0 on the spoilboard with my controller software and then moving my bit to the top of the material, setting x=0 & y=0, to get ready to start the cut. The result is that I get the router doing an air cut about 3/4" above the material.
I've also tried designating z=0 on top of the material, hoping that the controller would understand the G-code from Vectric. Again, I get an air cut.
I've also tried not designating z=0 at all with the controller software, but end up getting the same result.
I've attached a photo to give you an idea of my material/spoil board set up. The inked + sign is where I start my cuts. I've also attached the crv file.
I appreciate any help you can provide
- mtylerfl
Your z-zero location has nothing to do with your x,y start points. And, you certainly do NOT set your z-zero on top of your material if you have set it to the bottom in your Vectric file.
On my machine, I have it already set for the x,y start location. There is nothing further to do other than place my corner of the material there.
Then the only thing to do is set the Z-Zero for the bit. If the file I created has the z-zero set at the bottom, then I just lower the bit to an appropriate location of the spoilboard and it's ready to go.
I do not need to reset my x,y location because it's already done. Just start the project run and it will move to the correct x, y start point automatically.
Sounds like when you're doing the XY zero the controller software is doing the Z zero at the same time. Usually all 3 axis can be zeroed independently (at least on all control software I've seen). Double check that the routine you're using to zero the XY isn't re-zeroing the Z.
As Michael says there should be no need to reset the XY every job if you're using the same point. I haven't reset the XY on my machine for months.
If you ordered a full kit from Ooznest, it seems your machine is using grbl.
grbl users will give much more valuable information, but after giving a quick look at the grbl wiki, it seems it uses a fixed physical origin.
AFAIK, you'll need to define wcs (work coordinate system).
Have a look at this link: https://github.com/grbl/grbl/wiki/Using-Grbl
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
Last night after reading Adrian's advice regarding my controller, I went online to do some remedial tutorials. I discovered that I was taking an extra step in the zeroing process and may have been undoing my work. I did a couple "dry air" tests this morning, and everything is looking pretty good. I'll do a live test later this morning.
Michael: After understanding what I was doing wrong with my controller set up, it is very easy to establish the starting point at the spoiler bed as you had suggested.
LGM: Thanks for the additional info!
Thank you everyone for your help and patience getting me through this head scratching problem.
Steve.
Steve.
First "live" cut looked good with even profile cuts that went through the wood evenly on both sides of each piece. I just need to do a little fine tuning. This is definitely a better way to cut many profile pieces from sheet goods that need to go all the way through the material. All I need to do now is cut the tabs with a Dremel tool.
Thanks again everyone!
- mtylerfl
Thank you for the report, Steve. That's great news!
+1mtylerfl wrote:Thank you for the report, Steve. That's great news!
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
