Would like to make a round bottom bowl. Have tried using a dish from the clip art, but if I use the U or upside down U as the modeling mode, I get "domes" recessed around the edges about the height of the dome. Is there a way to turn a dome "upside down" ?
Thanks.
Can you turn a "dome" upside down in VCarve Pro
- DHDeitrick
- Model of CNC Machine: Maverick 3 x 5
- Model of CNC Machine: Axiom AR4
Re: Can you turn a "dome" upside down in VCarve Pro
Why not simply cut the dome and then flip over the piece and cut out the inside?
VCP 9 has two sided cutting ability.
- highpockets
- DHDeitrick
No I didn't, so I did. At least the model looks right. Will go try it & see what happens.
Thanks for the prod in the correct direction.
Don't really understand the Zero Plane yet, but have learned that it can be very important. Perhaps some day I can learn why & how to effectively use it.
Rule of thumb is whenever what you're making in 3D is below the surface of the material then you need a zero plane. Otherwise the software can have issues calculating where the edge of the model meets the surface of the material.
