Help holes in Vcarve
Makingtoothpicks
Model of CNC Machine: Cncrouterparts CPR2448
Post by Makingtoothpicks »
I have noticed in the past and now that Vcarve makes little holes when carving.
They are deeper then the v Carve and because it goes down much deeper then
the carving it is quite noticeable. Why and how do I prevent it from doing this.
It also takes time for the machine to run around and make these holes.
Sometimes it does then at the beginning and sometimes after. Here are some
screen shots. I do have Predator G-code reader I am not very good at it.
I will upload screen shots and G-code.
Don
New murphy 5.txt
(611.87 KiB) Downloaded 130 times
wmgeorge
Model of CNC Machine: Workbee 1000x750 Mach 4 PMDX Controller
Re: Help holes in Vcarve
Post by wmgeorge »
Is It always with the same font or does it do it on projects other than Text? I loaded into a toolpath simulator and it looks ok. What tool are you using and is it zeroed at the top of the material? Otherwise I have no idea.
Post by highpockets »
Looks like you have overlapping vectors. Convert the text to curves and run Vector Validator tool.
Makingtoothpicks
Darn those over lapping vectors. I have banished them to parts unknown. LOL
Don
I will let you know on my next test cut.
