Candlestone Source
wmgeorge
Model of CNC Machine: Workbee 1000x750 Mach 4 PMDX Controller
Candlestone Source
Post by wmgeorge »
So the only source for the Candlestone material that I can find is eBay and the vender seems to be "out of the office". There is not another source and I have googled nothing found. I finally ordered some 1/4 inch 6mm white Corian to try.
dwilli9013
Re: Candlestone Source
Post by dwilli9013 »
D-Dub
Dwayne
Dwilli
wmgeorge
Post by wmgeorge »
dwilli9013 wrote:Try this place.
http://candlestonegifts.com/
Thank you, Got it ordered, funny same company that was on eBay. So why do they leave the eBay ad up if they are not selling?
Barry Anderson
Model of CNC Machine: Shark
Post by Barry Anderson »
Good morning. I have never used candlestone. The website makes it look interesting. Would a regular v-bit be used or is a special bit required?
Thank you
Barry
wmgeorge
Post by wmgeorge »
Barry Anderson wrote:Good morning. I have never used candlestone. The website makes it look interesting. Would a regular v-bit be used or is a special bit required?
Thank you
Barry
Well having never done one yet, can not say for sure. But I plan on using a .125 or 3mm ball end mill or smaller if I can find. But the v bit would also be an option. I have Candlestone and Corian thin stuff ordered.
Samson
Model of CNC Machine: 4x4
Post by Samson »
The owner of Candlestone Gifts, claimed the material cuts much nicer than other solid surfaces. I've cut every brand of solid surface, and there's not a significant difference. They all cut and engrave about the same, none better than others, or worse either.
Just my experience. YMMV.
