Need help with a pen tool
- Model of CNC Machine: Pirahna FX
I purchased a holder for a pen/marker. I have no idea how to set it up so it can outline, or fill in lettering.
Anyone familiar with setting up a pen?
- Model of CNC Machine: WinCNC Hybrid
Re: Need help with a pen tool
The pen tool I have fits into a tool collet and actually holds a fine point marker. I set mine up as a regular end mill with a diameter of the width of my marker tip (about 0.045"). Mine allows the marker to float (move inside the holder) about 0.050" so I set it up so that it is zeroed with enough play to allow the marker to follow the material even if the surface is just a little uneven. If you get your diameter set correctly, you'll be able to fill with it as well.
A link to a sped up video of my machine drawing:
Mike Queen
Microsystems World CNC (WinCNC)
https://www.youtube.com/user/cncMike304
- dwilli9013
Thank you for that. I just got a few pen tip prototypes to review for a good friend. That setup makes it much easier. Nice video. That thing is smoking.
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
Thanks Queen,
Should I use either the Profile or Pocket toolpath to outline or fill?
Happy to help. Yeah, I did the drawing for my grandson's elementary school project. They showed the video to the students. Needless to say, the kids liked the drawing much better after they watched the video. My grandson was a hero for a day.dwilli9013 wrote:Thank you for that. I just got a few pen tip prototypes to review for a good friend. That setup makes it much easier. Nice video. That thing is smoking.
If your tool allows for a little free "floating" of the pen/marker, it makes it very easy to use.
One VERY IMPORTANT THING: MAKE SURE YOU USE A POST PROCESSOR THAT DOESN'T START THE SPINDLE. If you accidentally start the spindle, you're probably going to ruin the spindle and maybe throw some very heavy and dangerous parts around the room!
Mike Queen
I've used both.blacksmithED wrote:Thanks Queen,
For outline I usually just draw on the line. After all I want to represent my drawing correctly.
I've done some pretty cool fill work too. You can lie to the software and tell it the tool has a little larger diameter and get some fills that look about like hand scribbled drawings. You can have different tools for different colors too. Make a separate file for each color. Experiment... Play... Paper is cheap!
Mike Queen
I did a test. Came out great with both outline and fill. Spring loaded rig with a marker in it.
I have another question.
Since the holder is spring loaded, do I need to set a "cut depth"? Or will the software (Vectric) not go if there is no cut depth? (I can't do another test until tomorrow.)
Mine isn't spring loaded but it does basically the same thing with gravity. I always set mine to about 0.020" deep and a lift that will clear the material well for rapid moves. Then I set my z0 with it just a little compressed. That way it will stay on my material if it dips and has a little more to compress in case the material raises.blacksmithED wrote:I did a test. Came out great with both outline and fill. Spring loaded rig with a marker in it.
Mike Queen
- Martin Reid
Dear All
There is more on 'pens' below
http://forum.vectric.com/viewtopic.php? ... en#p200400
Sincerely and in good faith
Martin
Martin
I got the pen working fine except for one thing. After the pen is raised to move to another letter, it lowers to the paper extremely slowly. Like it's going as slow at the motor will allow. I don't see a setting for speed in the z axis.
Is the slow decent because I selected an engraving tool setup to modify for the pen?
Ed
Ed
The Z axis speed is the plunge rate.
- Xxray
Look in material setup, you'll find options for clearance and plungeblacksmithED wrote:I got the pen working fine except for one thing. After the pen is raised to move to another letter, it lowers to the paper extremely slowly. Like it's going as slow at the motor will allow. I don't see a setting for speed in the z axis.
Ed
Doug
in material setup, I have 0.2" for both plunge and clearance. Same as I always use, but never had the head move down this sloooooow.
- wmgeorge
Plunge Rate is the rate in inches or mm per minute the Z goes down, it should be set at 100 according to your screen shot. Has that been changed?blacksmithED wrote:in material setup, I have 0.2" for both plunge and clearance. Same as I always use, but never had the head move down this sloooooow.
The plunge rate was set at 100 in.min,.
Don't know what happened, but this afternoon I ran the program again and it worked as normal.
Strange.
Thanks everyone for you help. I really appreciate it.
Ed
Strange.
Ed
