End mill question
End mill question
Postby Bb0901 » Sun Jan 07, 2018 5:55 am
When setting the xy position to the lower left start position do you center the end mill bit to the corner of the material or set the edge of the bit to the edge of the material
Bill
Bb0901
Model of CNC Machine: Powermatic pm-2x2rk 2x2
Re: End mill question
Postby Rcnewcomb » Sun Jan 07, 2018 5:57 am
Center
Model of CNC Machine: Shopbot, CAMaster
Postby Bb0901 » Sun Jan 07, 2018 6:02 am
Thanks RC
Just confirming what I thought.
Bb0901
Postby KeithW » Tue Jan 16, 2018 12:02 pm
Slip in a V-bit (just hand tight enough to hold it) center on the point, and then put in the bit you want to carve with. It will be centered.
KeithW
Model of CNC Machine: Probotix Meteor, Aspire 8.014
Postby martin54 » Tue Jan 16, 2018 12:21 pm
KeithW wrote:Slip in a V-bit (just hand tight enough to hold it) center on the point, and then put in the bit you want to carve with. It will be centered.
I have done something similar using a D shaped engraving bit, quite easy to use the flat on the bit against the edge of a board but generally I just use the edge of the tool I am cutting with & set my x y position to the radius of the tool rather than zero.
Remember to set them as negative numbers though or the bit will move the wrong way :lol: :lol: :lol:
Postby Bb0901 » Tue Jan 16, 2018 4:46 pm
Keith
Makes perfect sense. Never thought of it like that.
Bb0901
Postby gkas » Tue Jan 16, 2018 5:13 pm
When I really need to be exact, I use this centering bit. I like it because you can use it in either a 1/4" or 1/2" chuck, and I don't chance screwing up a good V-Bit. https://www.amazon.com/gp/product/B003NE5ATG/ref=oh_aui_detailpage_o02_s03?ie=UTF8&psc=1
gkas
Model of CNC Machine: Axiom AR8 Pro+
Return to VCarve - General
Users browsing this forum: Yahoo [Bot] and 22 guests
