Can I authorize my trial copy of VCarve Pro?
- Rubiconlwb
- Model of CNC Machine: Piranha XL
I downloaded and have been using the trial version of the software ever since I ordered my CNC Piranha XL. It came yesterday and included a complimentary copy of the full version of the software. I have the registration key and the software on a thumb drive. Is there a way to register the trial software to make it a full use copy or do I have to uninstall the trial version and then load the full version from the thumb drive?
Re: Can I authorize my trial copy of VCarve Pro?
No you can't authorise the trial version & if you have created any projects using the trial version then you should install the registered version on the same machine before you uninstall the trial version, I would just leave the trial version on there until you are sure any projects you have created are working ok with the registered version
