If one chooses "machine bed" on the Job Setup section, what do you set the cutter at?
Is seems obvious that one would set the cutter on the surface of the bed. But then, if I use a touch plate, I would have to set the plate on the bed, correct?
Why don't we always use the Machine Bed option? If we did, we would never cut into our spoilboard. It seems like the machine bed should be the default.
If the machine bed is used to start from, then would one have to combine the thickness of the material with the Safe Z amount or will the program know to keep the cutter above the material and not the bed?
Ed
machine bed?
- Model of CNC Machine: Pirahna FX
Re: machine bed?
The program keeps track of it. On the material setup page the Z references for Z home, clearance, and plunge are all referenced as gaps above the material See this thread for more discussion: Where to Z?will the program know to keep the cutter above the material and not the bed?
Re: machine bed?
Thanks Randall. I've had surgery on my foot and have to be off my feet for nearly 6 weeks, so I'm in a chair trying to learn as much as I can about CNC so when I get back in the shop I'll be ready to knock out some of the many projects I have in mind.
Ed
Ed
- dealguy11
Re: machine bed?
Machine bed can be the default if you like. It does require that you accurately measure the thickness of the material. The look of some toolpaths, like v-carving and 3d carving is very sensitive to making sure the top of the material is defined accurately. Measuring from the top can make that easier.
Having said that, I always go from the bed nowadays. It makes it less likely that I will get a mismatch between Aspire and the control system concerning Z0. I've gouged enough spoilboards and broken enough tools so that I'm willing to to the necessary measuring.
Steve Godding
