DB-25
Re: DB-25
There are plenty of vectors of DB-25 plugs/sockets which you can find with a google search. You can then generate a cutting file via VCarve using one of those.
Problem with using someone elses g-code file is that the speeds/feeds etc could be totally wrong for your machine.
