Hello from Germany
Is the there a possibility to set a M7/M8 into the settings to each tool?
Some bigger tools into my projects needs a vacuum cleaner and the little bits dont need it. I want to toggle it automatically by M7/M8/M9 G-Gode.
...but how?
How to set M7/M8 automatically
- Model of CNC Machine: self made
Re: How to set M7/M8 automatically
You can do it with a change to the post processor and the use of tool notes or you can create a separate post processor that always has the commands in it and use it only for those jobs where it's needed.
Thank you Adrian,
What do you mean with "change to the post processor" How I can do it?
There is a post processor editing guide on the VCarve help menu. That will give you the information you need to make the changes if you're comfortable with editing files in Windows.
Hi Adrian,
I Think my simple english is not enough.
Can you give me the site in this help where I can find this? Then I can translate step by step.
Would you think my which can be a option for a Update- Probably any other users can profit from it.
Ron
Ron
- FixitMike
At the top left of your VCarve wiidow: Help, Post Processor Guide.
Help, Help Contents, is your guide to using the tools and toolpaths.
