I received a DWG from a client and I'm not able to apply tool paths due to the shapes not being closed vectors. It appears that each line segment is its own closed vectors therefore I can't join the entire shape. Any known fixes for this issue? The file is attached.
Luke
Trouble with joining open vectors
- Model of CNC Machine: Laguna SmartShop II
- Screen Studies CAD.DWG.zip
- (253.52 KiB) Downloaded 69 times
- dhellew2
Re: Trouble with joining open vectors
The problem appears to be duplicate vectors
Select duplicate vectors and delete them then you can join vectors (only 3 will remain open)
Dale
Dale
Young = time, no money
Old = money, no time
Dale
Dale
I joined both shapes with the join tool without any problems. Depending on what your toolpath strategy is going to be you'll probably have to do some cutting/joining of the vectors on the left hand shape.
- Closed Shapes.crv
- (31.5 KiB) Downloaded 68 times
