Will VCarve desktop accept dxf images?
Thank you for any answers.
DXF’s
- Model of CNC Machine: shark hd3
Re: DXF’s
Thank you for the reply. When you say popular. Which ones are you talking about?
Re: DXF’s
Have a look at the features, it lists the 2d file imports that it will accept
http://www.vectric.com/products/vcarve.htm
Re: DXF’s
PDF, SVG, AI, EPS, DWG, SKP as 2d vectors.
STL, 3DM (Rhino), SKP (Sketchup), RLF (ArtCam v9) , 3DS ASC PRJ (3DStudio), .X (directx), DXF, LWO (Lighwave), WRL (VRML),OBJ (Wavefront) as 3D models.
Re: DXF’s
Thank you for your reply. I used your link to the features. There are quite a few that it will accept. I only recognized about four out of the bunch though. I guess I could start reading a little more about the machine. I’m still learning a lot. I’ve only had it a little over a year and this machine still amazes me. I have cut a bunch of signs. I bought the laser engraver and I’m getting better at that. I’ve only cut one 3-D program. I’m trying to figure out how to turn a vector into a 3-D program though. I am limited to the 3-D files that came with the software. And purchasing them from other places.
Re: DXF’s
You can't really go from vectors to 3D with VCarve, you need Aspire for that although you can do a lot with moulding and fluting toolpaths. All depends on what sort of 3D shapes you're after.
Re: DXF’s
I just now started doing a few 3D carvings. Some of the files that came with the software. I like it. I just want to learn how to find a image on the internet and turn it into a 3D carving. Like I do with the signs that I have made for people.
