Cannot generate Job sheet after updating
I updated V Carve Pro to version 9.012 and now I get an error message when I try to generate a Job Sheet. Is this a bug in the update and is there a way tofix it?
Re: Cannot generate Job sheet after updating
What error message are you getting? 9.012 seems to be working ok for me.
Here is the message I'm getting.
- Model of CNC Machine: Axiom Elite
I have had the same problem and restoring did not solve the problem. And i was going to be organized and make a thre ring binders of my repeated projects
- Vectric Staff
- Model of CNC Machine: 6040 Desktop CNC
Hi all,
This problem occurs if you customised your job setup sheet with the editor in v8.5 and chose to migrate your gadgets from v8.5 to v9. As we have added new additions to allow for double sided which was not present in v8.5 this causes the error. The best way to solve this, is to either use the restore function within the Setup Sheet Editor, which you will find under the gadgets menu, or delete the _Setup_Sheet folder from your public documents folder which should follow something like this
C:\Users\Public\Documents\Vectric Files\Gadgets\"Insert software package name here" V9.0\__Setup_Sheet
eg
C:\Users\Public\Documents\Vectric Files\Gadgets\Aspire V9.0\__Setup_Sheet
Do not delete the _Setup_Sheet folder you find within the C:\ProgramData Folder as this is the software default setup sheet and will require a reinstall of the software to bring it back once deleted.
Hope this helps
Sean
eg
Hope this helps
Sean
