Material recommendations
GJHall
Model of CNC Machine: DIY 48x96
Post by GJHall »
New at trying to do this project, having a blast learning V carving, now I am wanting to try cutting some thin material for a project for my grandson. See picture below. This file was purchased awhile ago when I was cutting with a plasma cutter.
The file says to use1/16", 1/8", 1/4" or up to 1/2" wood. I would like to cut this in 1/8" material.
Looked at plywood, there was voids all over on the end so I think that would be a bad choice. They had some kind of hard board that looked like mdf. Not sure how that would work.
What would you recommend for material?
Gary
File was purchased from Makecnc, picture is from internet.
ger21
Re: Material recommendations
Post by ger21 »
Get some aircraft plywood from a hobby shop. It won't have any voids.
davemartin88
Model of CNC Machine: CAMMaster Stinger II
Post by davemartin88 »
Baltic Birch plywood. Is that the same as aircraft ply?
ger21
Post by ger21 »
Pretty much the same thing.
GJHall
Post by GJHall »
Thank you for the reply.
I will have a look around and see what I can f7nf.
Gary
