Mirrored image cutting inside
Postby duckmanwv » Sun Nov 19, 2017 9:52 pm
I mirrored an profile. The original profiles on the outside and the mirrored cuts on the inside. I used to know how to fix this but it has been awhile since I have did it. Any help would be appreciated.
duckmanwv
Model of CNC Machine: CNC Shark Routing System
Re: Mirrored image cutting inside
Postby Adrian » Sun Nov 19, 2017 10:42 pm
If it's supposed to be an open vector then you need to move the start node on one of the vectors. If it's supposed to be a closed vector then you need to use the join tool.
Return to VCarve - General
Users browsing this forum: FixitMike and 23 guests
