Controlling End Mill Cut Depth?
Postby johnelle » Wed Nov 01, 2017 5:39 pm
I just had a disaster trying to do a 3D carving on Oak. Bad chatter and eventually it broke away from the bed the vibrations were so bad. Going to slow the feed to 20 but I also want to cut down the depth per pass. For the 1/4 inch end mill it looks like it is taking almost 1/4 inch per pass. I don't see any way to control this on either the tool or path settings(?) Most other software lets you set it directly. Where is this in Vcarve?
1/4" straight end mill. Cutting 3/4 red oak.
johnelle
Re: Controlling End Mill Cut Depth?
Postby Rcnewcomb » Wed Nov 01, 2017 6:04 pm
When setting up the toolpath you can select the Edit button for the tool.
In the dialog box change the Pass Depth to the desired value.
Postby MRH91 » Thu Nov 02, 2017 12:19 am
Exactly as Rcnewcomb suggests, within the Tooling setup for your particular end mill (where you edit the feeds/speeds) it allows you to control the depth per pass also. I wouldn't go much beyond 1mm, but thats completely up to you, I would rather it take longer to carve and have a smoother, chatter free carve.
MRH91
Model of CNC Machine: X-Carve 1000mm
Postby Rcnewcomb » Thu Nov 02, 2017 12:27 am
You can also change the setting in the Tool Database and it will use that value by default each time you select that bit. You can still override it on a particular job using the method mentioned above.
To change in the Tool Database
Toolpaths/ToolDatabase
Change the values and click Apply or OK to save them.
Postby Leo » Thu Nov 02, 2017 1:08 am
If you are doing a 3D finish toolpath the cutter is going to go to the full depth.
If you want a controlled depth per pass as mentioned by the other guys you need to use the 3D roughing toolpath first.
www.leosworkshop.com
Leo
Users browsing this forum: No registered users and 23 guests
