Tool path sequence
Tool path sequence
Postby MWinn » Wed Oct 25, 2017 10:58 pm
I have created several projects where I first make sure the order of the toolpaths is what I want, usually the cutout of the project is last.
I then select all the toolpaths and save them as a single file.
I am using UCCNC and when I open the file and run it it starts with the cutout which was last in the list.
Am I missing something?
MW
MWinn
Model of CNC Machine: StepCraft 840
Re: Tool path sequence
Postby mtylerfl » Thu Oct 26, 2017 12:07 am
Questions...
1) Is there a post processor in the list that supports ATC (automatic tool changer) for your specific machine?
2) Are you actually using the ATC post processor when you calculate your toolpaths?
3) If "yes" to questions 1 & 2, are you assigning each bit its own exclusive Bit Number?
Postby IslaWW » Thu Oct 26, 2017 2:43 am
Is the box: "output Visible Toolpaths to One File" checked?
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby adze_cnc » Thu Oct 26, 2017 6:26 pm
Does this UCCNC program need to have its tool list in the same order as your VCarve list? That is to say could UCCNC be remapping the order of your cuts based on some tool selection order that it might have.
adze_cnc
Postby ger21 » Thu Oct 26, 2017 6:38 pm
No, UCCNC will cut exactly like the g-code is written.
Gerry
ger21
Users browsing this forum: LittleGreyMan and 16 guests
